shavermcspud
- Mar 12, 2020
- 573
Thought id give something back to the community.
Not sure if its been done before, I didn't see it here, but I have managed to decode the data from a wide variety of PV inverters, Grid tie, storage etc, written a python script that outputs to influxdb then you can read off in to grafana or similar.
Any that use the huge hex data values basically
i.e Canadian solar, Solis, Sofar, Ginlong (any type) if it uses the wifi stick or lan adapter you can pull the values, from my brief research there are around 90 odd inverters that use these same hex values. This doesn't work for the MPP USB/RS232 or all in one units but I think that's already covered in ICC solar plus many other bits of software.
I have made a pre configured Raspberry Pi image if anyone wants to dive straight in, or I can provide the python script. the hex values
