Quattrohead
Emperor Of Solar
I can tell you that in my experience the Dihool breakers are substantially better than all the other brands on Amazon. Whether they are as good as Siemens or GE etc is up to you but I am trusting them in my system.
You should spend a little more time in the Forums before you commit to that, but it's only money.four of them in series for a 48v setup, with paired victron 48/3000 multiplus-II inverters, in a cabinet type setup. as a temporary "power outage" pack that i can generator recharge. L14-30 inlet and outlet, with the victrons set to limit draw to the generator limits.
breakers, fuses, etc all wired up so that overloads trip protection.
these claim to be designed to be battery disconnect and circuit breakers combined. do we trust them?
That sure looks like a westinhouse unit.Anatomy of a MCCB - this one was $36 on aliexpress
With the cover off.
The arc chutes, 1/2" wide and 1.25" tall
Where the arc chutes go.
Very good quality and I wouldn't hesitate to trust it as a switch.
Below are some additional brands
Top quality is TOMZN closely followed by TAIXI.... then the ZOII but it doesn't have lubricant at the moving points... and the BAOYI in a distant last place.... CHINTZ comes in below the TAIXI and TOMZN but higher than the ZOII
All of the ones I have in my possession are marked for line/load...
They are built very beefy with good sized contacts and springs. The cheap ones are missing lubricant at all the moving points.
The DIHOOL and TOMZN are lubricated and the seem to have better bolts for attaching the wires. The black TOMZN also have an extra shield plate for the arc arrestor. And are sold as 1000v.
The Taixi and Baoyi brand doesn't have any lubricant at all and the the fit of the case is less than perfect.
I would trust any of them as a switch and to carry the current. The DiH00l and Tomzn should work as a breaker as well. I don't think I would trust the non-lubricated version might not work so well after a while if there is any corrosion where the moving parts come together.
or you could just tell me what you think the problem with it is instead of just making vague and meaningless statementsYou should spend a little more time in the Forums before you commit to that, but it's only money.
I could but that would take the fun out of it. Seriously, putting 12v batteries in series with independent BMS's is sub-optimal. Just get a rack unit for similar money.or you could just tell me what you think the problem with it is instead of just making vague and meaningless statements
edit: are you worried about total load? my critical loads panel averages around 1-1kW of usage. much of which can be shed if needed. dual multiplus-II 3000s gives 3kW for each leg.
again, name the problem. the manufacturer supports running these in series, sells a battery balancer for them. they support up to 4P4S arrays for them.I could but that would take the fun out of it. Seriously, putting 12v batteries in series with independent BMS's is sub-optimal. Just get a rack unit for similar money.
the rackmount batteries cost 25-50% more per kWh and gain my nothing since it's a portable system that i don't need to worry about fixed system UL standards for.
i said in the post before yours that LiTime sells a balancer for that purpose.The problem is keeping the 4 batteries in series balanced. What will happen is they will drift due to internal resistance and over time one will go into protection mode before the others and you will loose all power from the string until you wake up the one in protection.
You can use an active equalizer to try and keep them in balance or every few months you will have to take the string apart and charge them in parallel at 14.4v for a day.
It is ALWAYS much preferred to have a single battery of the correct voltage verse putting them in series to get it.
So you are buying a high-end Victron "Euro-trash" (giggle) inverter, but you are going to cheap out on the batteries? What you are looking at is not going to scale that well, but if you are just experimenting it will all work.
Hey @Denidil
Just because the manufacturer says it can be done doesn’t make it best practice.
IMO best practice is as simple as you can make it for your given budget & use.
Adding a balancer adds complication, thus less simple
Less is More![]()
RV is a different game, Victron is probably a better option, their stuff is compact and durable, but I'd still do a rack battery. We are drifting way off topic for this thread.Less for more $ is less for more $
Running strings and parallel arrays is an entirely standard setup in portable setups like RVs.
Nobody has actually given any reason why standard practice is wrong except vague statements that don't name any actual problems. Will has reviewed these batteries, this is a standard way of setting things up in RVs - to the point where there are dudes with almost 8kW of solar panels on their RVs, with 30-60kWh of batteries, EV chargers off their RVs, etc.
That includes professional installers doing this.
We are totally off topic nowRV is a different game, Victron is probably a better option, their stuff is compact and durable, but I'd still do a rack battery. We are drifting way off topic for this thread.
The Chevy with a blown engine is a yard ornament. The little blue truck, brand new, may not hold much but you can cart something of substance from point a to point b not to mention get to town to buy parts to fix the dump truck. Comparing a dump truck to a tiny pickup is kinda dumb.To use the used car analogy.....
We are talking about the difference between this
and this
And your worried about how many miles are on it.
As long as they have an AC rating physically printed on them, something like ~240V or ~480V, no downside.what, if any, are the down side of using double-pole DC circuit breaker in AC application ?
