I need y'all to review my plan to charge my 24V house bank for $18USD.
Dasiter 600W High Power DC to DC Boost Converter DC 12-60V to 12-80V Boost Module Board Step-up Transformer
I have been pulling a travel trailer with a van. It is a 30A trailer. One way to describe my rig is a split 'B'.
Where most rigs have all of the electrical in the trailer, the van is my main source of VAC for the trailer.
This plan was started when my 12V inverter/charger in the van went toes up. Right now, the 600AH bank is being charged by solar and the alternator. There is a 6Ga positive cable with a 25A in-line fuse between the starting and house bank with a chassis ground return, very parallel. The current is between 20 and 25A because I blew a 20A fuse but the 25A has held up. I don't want to lose this charging source.
I am changing to a 24V house system with a Growatt 3000 24V AIO. The AIO will replace the existing SCC and Inverter/charger. The 12V, 600AH bank will be rewired to 24V, 300AH.
Defs:
House - the 24V 300AH AGM bank.
SCC - A 15A limited 24V MPPT with max 400W input draw. VOC = 60V. It will ignore excess Amps/Watts. I have this.
Boost - the $18 device I need in the link above. What I need this device to do is present a psuedo 400W(12A * 33V) panel to the SCC.
BIRD - Bidirectional, Voltage sensing relay. I have this.
The flow :
House <- SCC <- Boost <- BIRD <- alternator.
Can the Boost's Volt and Amp pots do this?
Will I have ground issues?
