sunrise
- Jul 16, 2020
- 206
Hi folks,
I recently installed a Victron Orion-Tr 12/12-18 DC-DC smart charger on my travel trailer. it's connected to TV (SUV) via 7pin trailer cable and the fuse in the TV is 20A - that's why I purchased the 18a charger - I do not want the charger to draw too much current that trip the fuse.
Well, that didn't work, it already trip the fuse several times - it turned out the 18a is just that the charger will be able to put out 18a continuously, I did a bit more research on this and found that the charger could draw 25A for a brief amount of time (~10s), enough to trip the fuse. So for now I had to go to charger settings to lower the absorption voltage from 14.4 to like 13.6, to limit the current, but this only works if the battery still has enough juice in it, if it is nearly fully discharged then the voltage difference would still cause a current too high.
Is there any inline device that I can use to limit the current? seems like it's going to be hard to find a resistor rated at 15a, plus it's probably going to generate a lot of heat. I do not want a separate wire from the alternator, It's a mid-size SUV and it's very hard to run wires from alternator to hitch. I would be pretty happy to have a 12-15amp charging current.
Thanks in advance.
Thanks in advance.
