aippolito184
- Aug 8, 2020
- 37
It is a Xantrax Freedom 458 30A, not designed for lithium. The main fuse I speak of is the 300a, it feeds a panel with a plethora of other fuses. So if the battery can handle 560A continuous and the fuse is 300A it sounds ok with the BMS.
In regards to the alternator scenario, I plan to remove the solenoid and install and Amp-L-Start to charge the chassis battery from the house when it is charging (solar, shore, generator) and then a DC - DC charger that will be controlled by the ignition to charge the house from the alternator while the coach engine is on. Solid plan? Anything you would add?
