fitzfarseer
- Nov 13, 2021
- 9
Hi all,
Tried asking this over on the Ford Transit forum, but to no avail. Thought you fine folks might be able to offer more wisdom!
Currently planning out the wiring and electrical components that will be going in my camper conversion, and I'd like to use a DC to DC battery charger in order to charge the van battery and the leisure battery via the alternator when driving as well as through solar. I'm looking at the Renogy charger with built in MPPT at the moment due to the cost, ease of use, and ability to charge batteries of different chemistry simultaneously, although I know this has limitations, so I am looking at other available chargers, such as those by Victron and Redarc.
However, my MK7 2010 Transit has two batteries under the drivers seat. From what I understand, the back one is the starter, and the front one is the auxiliary battery, and that they are only connected when the ignition is on. I believe they are connected via a split charge relay, or something very similar.
My question is would it be possible to charge both these under seat batteries as well as the back leisure battery using this one DC to DC charger, and how I might go about doing that? Or if that isn't a goer, any other ideas? Removing the under seat auxiliary battery entirely?
I ask because it is likely that I won't be driving the van too much, and I don't want the auxiliary battery dying, as I've heard it can cause all sorts of strange things to happen...
Worth noting that the under seat batteries are both lead-acid, whereas the leisure battery is lithium. All 12v.
Cheers!
Cheers!
