Am expecting a 4S 100Ahr "A Grade" LiFEPO4 JK-BMS from Amy (Luyuan). In anticipation of using this as a camping battery in a recreation vehicle, about 6 months ago I purchased a Atem Power 40 A DC DC charger model VABG008A. Atem Power come from a company in China - Zhejiang Vicoffroad Vehicle Accessories Co., Ltd
and have a presence here in Australia - website- vicoffroad.com.au
Even though the profile is labelled "Lion" on the charger settings I was reassured that the profile was suitable for LiFePO4.
There were a few comments on Amazon that this "Lion" profile was not suitable for LiFePO4 as it had an unaccepably low return to boost voltage of 12.4V.
I decided to bench test the DC-DC charger and check the "Lion" and "Lead" profiles. The user manual mentions some voltages for profiles but is incomplete. It does describe a floating voltage of 13.5V for AGM/Gel, Calcium, Lead and says there is no float voltage for LiFePO4.
My testing:
Lion - softstart then full charge to 14.4V and then CV until current tapers to 4A and full charge light comes on and then there is no maintenance charge or float voltage and battery voltage slowly falls (depending on load) until it hits 12.35 V and then full charge to 14.4V starts again. So yes there is a return to boost a 12.4V which is close to an empty 4S LiFePO4 pack.
Lead - softstart then full charge to 14.4V and then CV until current tapers to 4A and full charge light comes on. The charge current is zero if there is no load and the pack drifts to its resting voltage, if there is a load then there is charge current to match outgoing and battery floats at 13.5V. I presume that there may be the same return to boost voltage of 12.4V but the volatge doesnt get here because of the float charge able to maintain a CV 13.5 ( not aware if there is a time limit)
I have taken this up with vicoffroad.com.au and gently asked them - please explain the "Lion" profile and was brushed of with a reply showing a LiFePO4 volts vs SOC table. No reply via the alibaba messaging service so far.
So without going down the track of trying to return the DC DC charger - the "Lead" profile as I have described looks possibly suitable for my 4S pack?
I notice Redarc and Renogy have gone away from listing battery chemistry profiles but describe the profile voltages.
I would welcome comments about using this "Lead" charging profile for my LiFePO4 100Ahr 4S pack.
Zhejiang Vicoffroad Vehicle Accessories Co., Ltd. - Camping Light, Battery Box
Zhejiang Vicoffroad Vehicle Accessories Co., Ltd., Experts in Manufacturing and Exporting Camping Light, Battery Box and 0 more Products.
vicoffroad.en.alibaba.com
My testing:
