meetyg
- Jun 4, 2021
- 1,090
Hi.
I have a general question about DC-DC chargers. I'm guessing that not all products are alike, but probably work the same:
When does a DC-DC charger stop charging the battery to be charged? Is it based on voltage only, or based also on current?
For example, if the DC-DC charger sees that the battery is at (or above) the charging voltage (for that chemistry), will it stop supplying power all together, or will it continue to supply power but at a lower current?
I was looking at this product for a little experiment I am doing with my EV:
I want to try to offload the auxiliary loads on the 12v system of my EV by supplying power using some solar panels, and another battery pack (please don't comment on the costs/feasibility, I have already gone through all that on an EV forum). The goal is to use less of the high-voltage battery and more from solar. But because space is limited for panels, I am planning to charge another battery (say a Lifepo4) while the car is parked using solar, and then while driving supply that power to the 12v circuit, in parallel with the existing 12v battery (some form of Lead-Acid).
The problem is I'm afraid that because the EV has a DC-DC converter on board (taking power from the HV battery and supplying it to the 12v battery and loads), the DC-DC charger ( the one I want to add) will see that the 12v circuit already has high voltage (around 14.4v) and won't supply the 12v circuit with power from my lifepo4 battery.
Does this make sense?
My other option is simply to get a generic DC-DC boost converter with adjustable output voltage and current, which I will set with a voltage high enough to overcome the on-board HV DC-DC converter (let's say 14.6 volts).
Thanks in advance....
DC to DC Battery Chargers|12V Battery DC to DC Charger-OLYS
DC to DC battery chargers designed to get the most out of your battery powered vehicle,keep your secondary battery charged whilst driving
www.olyssolar.com
