Folks
I have a trailer install. Thus no jumpers from an ignition switch. Just the 7 pin trailer connections.
I have a couple of installation questions about my Renogy 40amp DC DC charger with 2 200AH Lithium Batteries (ampere time)
Question 1: So I have seen were folks put in a switch that sees 12V and turn it to the on position to enable the DC/DC and turn it off when they dont want to pull from the tow vehicle. As I always drive with my running lights on to energize my rear view camera, I was thinking of tapping that voltage. That gives me control from the tow vehicle. Any reason NOT to do that?
Question 2: I was way focused on my alternator capacity and how much current the batteries could draw / need. 40 amps seems fine. I have an F350 diesel with the tow package, I believe that is a 120 amp alternator. Howerver, now that I look at the trailer wiring... 10 ga. Hmm. Thinking I should exchange for a 20 amp. Can I get away with the 40 amp? or was that a mistake?
Question 3: I managed to isolate the individual hot wire from the trailer umbilical to the 12V system. But dammed if I can find an isolated ground. Any reason both ground terminals cant simply go to the chassis ground? I have good continuity from the chassis point to the plug. Meter fluctuates between 0 and 0.1 ohms
Any help is appreciated
Andy
Andy
