paulclinger
I went through the discussions I could find on this forum about battery fuses including the fusing guidelines (https://diysolarforum.com/resources/dc-fuse-and-breaker-sizing-and-placement.129/), but am still a bit confused about what positions and devices should be used in my specific case.
Let's say I have a configuration with a 12kW inverter that has two EG4 batteries connected to it. The diagram on p9 of the fusing guidelines covers inverter/charger (which matches my configuration), but it only has one battery and it shows an external bus bar, which I don't have (as the EG4 Wallmount battery has an internal bus bar, so I plan to connect two of them directly). Given this I have the following questions:
- If a battery has two positive wires to the inverter, do both need to be protected with a fuse? Given that fuses protect wires, I assume the answer is "yes", but would like to confirm.
- I plan to daisy chain the batteries without using an external bus bar. The diagram on p9 shows OCPD1 "sized for total load" between the battery and the bus bar and OCPD2 "sized for inverter load" between the inverter and the bus bar, but given that the bus bar is internal in my case, do I just use a fuse sized for inverter load?
- Given the discussions using a MRBF terminal fuse or a class T, is having a class T fuse connected to each positive battery terminal sufficient or is it still advisable to add a terminal fuse? Or is it only considered in configurations where it can replace some of class T fuses, as it's smaller and cheaper (but with worse AIC protection)?
- Where do you normally place the fuse holder? All the images of batteries connected to inverters I've seen show a conduit box sitting on top of a battery and below the inverter, so does the fuse holder go inside the conduit box?
- What specific devices can be used as OCPD1 and OCPD2 shown on those diagrams? In my case, it's 2 280Ah batteries connected in parallel to one inverter. If having 250A or 300A class T fuse connected to each positive terminal is enough, what devices/holders can you recommend?
Thank you.
Thank you.
