bsr
Please see the schematic of the system I am wiring up. This is from the installation manual of Conext™ XW Pro. I have couple of questions regarding DC grounding.
1. The AC side is grounded through the utility. (top ground bus bar in the PDP). It doesn't show explicit grounding for DC side. Do I have to run a wire from DC grounding bus bar of PDP to grounding rod?
2. Schneider Conext MPPT 100 compatible with either negative grounded, positive-grounded, or ungrounded (floating) PV arrays. From reading many posts, I see negative grounded system are most common, and recommended. I do have my solar panels (frames) connected to a ground wire and can bring to the charge controller or connect to a rod directly. Should I ground the panels and keep the pv/charge controller floating, or should I bring the panel ground cable to the charge controller and negative ground the DC side.
Thanks
bsr
Thanks
bsr
