yabert
yeap: https://diysolarforum.com/threads/eaton-amx-and-amh-fuses-alternative-to-class-t.60804/Maybe somebody else will chime in on some reasonably priced fast blow t-class fuses
Only you can decide what risks you are willing to take when it comes to fuses/breakers.I just watched a few of Will's videos and he doesn't seem to fuse batteries that are low capacity like these
No, I've always said that you need OCPD. Always. Some batteries have a built in t class fuse, so those are fine without. But it still has it.I just watched a few of Will's videos and he doesn't seem to fuse batteries that are low capacity like these
Yes, need OCPD. Most 48V now have them built in luckily. DC rated circuit breaker and OCPD in the BMS. Works great. Just need proper size conductor so it will work properly.Only you can decide what risks you are willing to take when it comes to fuses/breakers.
A low capacity battery can still fail and potentially start a fire on the relatively smaller wires / bus bars it uses vs a larger battery with bigger wires / bus bars.
I'm not sure if @Will Prowse would consider a 150ah to 200ah 48vdc lifepo4 system to need some fuses/breakers or not, I suspect he would, but I don't want to put words into his mouth.
Those are pretty awful, lots of poor reviews from forum posts, including welding shut and catching on fireThanks.
So this one doesn't have a breaker. But does the BMS have enough protection to not need a fuse?
I was thinking of adding a breaker like this to each battery, but not sure if I should fuse each too
The ecoworthy is back in stock, but they upped the price. I'm guessing they will be 720 by the end of the week if nobody buys them at 880So eco-worthy responded to my eBay message and said they have a backlog of orders and are not expecting to restock until next month. By the wording it sounded more like January to me not December. And they said they aren’t sure if they’ll be doing that level of pricing again but that’s a pretty open ended answer.
I’m gonna just stick with the dc house batteries I ordered, I can pull the Bluetooth bms data into home assistant pretty easily it looks like so that’s my only real need.
$278.50 each, if you buy two or more at once.
My understanding on these credits is that you could have made the purchase previously, but that you can take the credit once you put the equipment into operation... Meaning if I bought batteries say two or three years ago but just pet them in storage and did not put them into a system then I would not be able to take the credit, but if this year for instance, I did go ahead and press the batteries into service, Then, even though I purchased the batteries two years ago, I could take the tax credit when I do this year's taxes...Oops, misread it, yeah you’re correct it’s just for vehicles.
Really tempting to order a 15kwh battery from docan then if I can get 30% off.
That's because every single one of those I've looked at has been rated for 48V. That is 48V max, not 58.4V. Honestly, I don't even know why use of supplementary overcurrent protection is even a question. Even if the battery has a breaker, just add an appropriately-rated fuse for safety and piece of mind. It's a few extra $$ out of a multi-thousand dollar system.Those are pretty awful, lots of poor reviews from forum posts, including welding shut and catching on fire
IKR? It seems like it was only yesterday batteries were a buck a watt-hour.88$ / kWh...![]()
Closer to $94/kWh unless I'm missing a deal?88$ / kWh...![]()
two pack for 499 w/ a $50 coupon = 450, so $225 each :D
Edit: I couldn't pass this up, so I purchased the 2 pack for $450. Slated to arrive Dec 9th, so I'll try to do some capacity testing and report back.
No. there aren't 48V x 50Ah, but 51.2V x 50Ah. Time 2 batteries.Closer to $94/kWh unless I'm missing a deal?
I don't need or even want batteries, but at this price, I couldn't pass it up.
Good point.No. there aren't 48V x 50Ah, but 51.2V x 50Ah. Time 2 batteries.
So, 450$ / 5.12 kWh =88$kWh.
Since these have 50A BMS, I don't need bigger than 2 AWG cable, right? If I want to oversize, max 1 AWG is needed. Am I calculating correctly?
Some people have accused me of having OCPD (Obsessive-Compulsive Personality Disorder)No, I've always said that you need OCPD. Always. Some batteries have a built in t class fuse, so those are fine without. But it still has it.
All of my blueprints have OCPD for every single conductor. And fuse blocks.
If I'm doing tests in my videos, no OCPD
I honestly thought that is what he meantSome people have accused me of having OCPD (Obsessive-Compulsive Personality Disorder)
Way to big for nothing.Since these have 50A BMS, I don't need bigger than 2 AWG cable, right?
Thanks. It's about 1 foot to bus bar. (I'm running 4/0 cable from bus bar to inverter in case I overdo it in the future, just to future proof). Would it change anything if I'm paralleling 4 of them into the bus bar?Way to big for nothing.
As they can only be discharge at 50A, you can use 6 awg if the distance from the load is short (let say less than 10-15').
Even 8 awg could be fine if 50A is only for peak power and average discharge current is lower.
No, each will supply up to 50A if the inverter ask 200A.Would it change anything if I'm paralleling 4 of them into the bus bar?
