I’m saying that positive should be on terminals 1 and 2Depends on what you call the load and what will be the fault it is protecting against. It could be correct.
It probably would have failed anyway. I don't have much confidence in breakers from China. I did some testing with DC breakers and polarity didn't matter much. One actually performed better backwards.There is a video out there where a guy says those are dangerous and he hooks it up backwards and it catches on fire a few minutes after he turns it off.... well duh, hook a polarized breaker up backwards and havok ensues.
Even though the OP's markings are different, positive is always on the right in your world?The wiring is fine and correct. Watched a million videos on this when I hooked up my system. That is how you wire it and how every other PV focused MCCB breaker works.
Yep, you’re right. I went and looked at my MCCB’s and every other similar one I have which are all positive on the right and assumed his was the same, and didn’t look at the little diagram. My mistake.Even though the OP's markings are different, positive is always on the right in your world?
That's the wonderful thing about standards, there are so many to choose from.Yep, you’re right. I went and looked at my MCCB’s and every other similar one I have which are all positive on the right and assumed his was the same, and didn’t look at the little diagram. My mistake.
With that said, EARU’s diagram shows the red (assumedly positive) on the right.
Your image is a MCB not a MCCBYep, you’re right. I went and looked at my MCCB’s and every other similar one I have which are all positive on the right and assumed his was the same, and didn’t look at the little diagram. My mistake.
The diagram on the breaker shows (+) on the left. I would follow the diagram on the breaker.Yep, you’re right. I went and looked at my MCCB’s and every other similar one I have which are all positive on the right and assumed his was the same, and didn’t look at the little diagram. My mistake.
Yeah, I’m just striking out today. Apparently need to go get some sleep.Your image is a MCB not a MCCB
