Hi I am from Southeast Asia and there are some DC power supplies lurking around.
Having to live closer to China can have its own benefits and drawbacks (shipping, quality respectively)
I was just wondering if there are a lot of these DC power supplies what should I prioritize in purchasing?
A higher voltage? or a higher amperage?
It seems that the answer is amperage since it affects the rate of charge.
Does anyone charge batteries using this in a 4s or higher config which results in 24 or 48v?
Or do you usually top balance things in basic 12v individually then lump them together later?
Available options are 15v 50a or 30v 30a and some combinations here and there.
What I plan to use this for is both top balancing and charging from low state of charge.
Btw they cost around 200USD should I bite the bullet? or a lower wattage total is enough like 12v 10a?
I also can't verify the quality of the product yet... so it is a risky purchase.
