Modular Hippo
Happy New Year Fellow Solar Enthusiasts
Got a question that I hope someone might be able to give advise on.
I am putting together a traditional 48v system (2 x Seplos Mason as battery bank). The bank will be charged mainly by solar, but at times by generators and grid.
The battery bank will be traditionally connected to an inverter to give me AC for domestic use. The Inverter will allow me to run the load 100% of the grid when connected, or for example the generator if running (only use the battery bank when needed).
Here comes the question: The battery bank will not only be used for domestic AC use, but also to power an 48v DC Motor. What I am trying to understand is that if the DC Motors are connected directly to the batteries (and the solar panels generate power as well as my generator) then will the motors take electricity from solar and generator first before topping up any missing DC from the battery bank? Or will I potentially run into complications here? I guess that what I am trying to say is that I want the motors to always take what it can from the solar and generator before it uses the battery bank. If the motors draw less power then what the generator then would any surplus from the generator charge the bank? The behaviour I am after is what the DC to AC inverter gives but as this is DC to DC and not controlled by an inverter I wonder what the complications are?
I guess I could go via the inverter and go back to DC (in other words, from solar DC to AC via inverter, and after that us a rectifier to go back to 48v DC again). By doing so I could use the intelligence and configuration to set order of where the power should be taken from and what to do with surplus. BUT the reason for being reluctant in doing so is that I have read that between every conversion (AC/DC and DC/AC) you lose between 5-15% in energy loss. Converting twice could in theory (if correct) make me lose 30%. Any thoughts on how to best connect the DC motor highly appreciated
