For those yes, but for trailer house battery (via the DC-DC charger) _and_ the trailer/tow vehicle ground being grounded all together?They normally are grounded together for trailer lights / brakes to work.
Your using the chassis as ground for the house battery? I don't see an issue with thatFor those yes, but for trailer house battery (via the DC-DC charger) _and_ the trailer/tow vehicle ground being grounded all together?
No I'm not, all of the interior lights/fridge/etc off the battery is isolated from the chassis. Which makes me hesitant to put that in the same GND as the chassis/tow vehicle. I don't know enough to understand the issues or ground loops or what not that that could produce, so I decided to go for isolated to be certain.Your using the chassis as ground for the house battery? I don't see an issue with that
I'm not sure what your asking to be honest. There's plenty of system with dual voltage systems using the same ground.No I'm not, all of the interior lights/fridge/etc off the battery is isolated from the chassis. Which makes me hesitant to put that in the same GND as the chassis/tow vehicle. I don't know enough to understand the issues or ground loops or what not that that could produce, so I decided to go for isolated to be certain.
So having a ground connection with the connection point at the DC-DC charger between trailer/tow vehicle chassis & battery isn't a problem?I'm not sure what your asking to be honest. There's plenty of system with dual voltage systems using the same ground.
As long as it can handle the current requirement.So having a ground connection with the connection point at the DC-DC charger between trailer/tow vehicle chassis & battery isn't a problem?
Good to know, nice, thanksAs long as it can handle the current requirement.
Hm, not sure what you mean. While in motion, driving down the road, you're saying get an inverter for the car, and then an AC charger in the trailer?! This is charging the battery while in motion from the alternator via the 7-pin trailer connection. Which is setup for DC from the tow vehicle, it would be extra, separate, 120VAC wiring that would need to be added, waterproof quick connect, etc.For a vehicle to trailer power connection of any significance, consider to use 120 vac instead of DC. Smaller wires and safer.
I'm confused by what was said too. Dc-dc charger is the simplest easiest way. No shock hazard compared to 120vHm, not sure what you mean. While in motion, driving down the road, you're saying get an inverter for the car, and then an AC charger in the trailer?! This is charging the battery while in motion from the alternator via the 7-pin trailer connection. Which is setup for DC from the tow vehicle, it would be extra, separate, 120VAC wiring that would need to be added, waterproof quick connect, etc.
Uh, there are 2 separate things when towing. 1) trailer turn signals, brake lights, electric brakes, etc, and 2) charging from tow vehicle alternator any house battery(ies).Yes, correct. I am guessing that your trailer already has a 120 vac charger if the battery is of any significant size.
Let's assume that you want to charge at 1 kW from the vehicle to the trailer. That is easily done with 10 awg out door extension cord using 120 vac, but would take a wire pair, each wire the size of your thumb to do in 12 volt DC.
If something goes wrong, an ordinary breaker will almost instantly stop the flow and can be just re-set. Doing that with 12 volt, it will arc before shutting down.
If your goal is just to run some lights while driving, then that is different and can be done via trailer connection wiring, but not any serious amounts of charging. Maybe 50 - 100 watts tops.
Probably 10-15% in losses in double conversion to go 30'?Yes, correct. I am guessing that your trailer already has a 120 vac charger if the battery is of any significant size.
It's not load on the engine, it's load on the alternator. Not all tow vehicles have a honking alternator. I tow with a Volvo station wagon, a small trailer. Not sure what size alternator is in there, but I doubt it's a 200+a like a F-150 or the like has. 1kW is call it ~80a, which I wouldn't be surprised is close to the same size as my car alternator. Your use case isn't the same as my use case isn't the same as OPs use case.Possibly, but even 1 kW is not much load on the engine while driving, so 100 - 200 watts of loss is negligible.
If you have a van that is close to 20 ft long, and then batteries in the trailer that are another 10 ft from the hitch, that is 30 ft, or 60 ft round trip wire length. Pushing 12 volt through 60 ft of wire is a big ask.
Next - think about your wife or kids connecting / disconnecting that 12 volt wire - live, vs disconnecting a 120 vac plug that they do every day.
The DC will always have a healthy arc, while AC quenches quickly and no one thinks twice about.
____________
Imagine that you are getting ready to leave for a trip, and realize that the 4 kW-hr trailer battery is low SOC, in a couple of hours of driving, it will be mostly charged up. Solar on the trailer can help to keep it charged during use.
Also the Orion XS can be de-rated so it doesn't pull the full 50A.It's not load on the engine, it's load on the alternator. Not all tow vehicles have a honking alternator. I tow with a Volvo station wagon, a small trailer. Not sure what size alternator is in there, but I doubt it's a 200+a like a F-150 or the like has. 1kW is call it ~80a, which I wouldn't be surprised is close to the same size as my car alternator. Your use case isn't the same as my use case isn't the same as OPs use case.
Although I'll agree he needs to choose different wiring setup if he wants the Victron Orion IP67 12/24-50A. Those are made more for RV/van alternator charging, which can have a lot shorter wiring runs and importantly don't ever get disconnected.
And like I said, the 7-pin is limited to 30a by the spec. Now I agree that 30a 12vDC is still more than I'd like for random connect/disconnect (for me, I actually have a shutoff switch I do), but also it's nowhere near 1kW or the like like you're saying. OP has a van setup he's doing. I'm the one that brought up tow vehicle & trailer setup.
