Benzimidazolone
- May 5, 2020
- 48
Has anyone tried the DC water heater element supplied by Missouri Wind and Solar for domestic hot water supply? The elements have a thermostat, so you don't have to worry about over pressurizing/overheating things and they have DC rated contacts so you don't have to worry about burning the switches. The issues seems to be that they are only 700 watts. Therefore, you could hook up 2 X 48v panels of approx 350 watts in parallel. You would have to do both the top and bottom elements but you would only have 1400 watts of power (and probably less because you would not size at the very upper limit). Is that enough power to hear a typical 40 or 50 gal tank (I realize it depends on how much hot water you use). My location is in the Bahamas (200 miles east of Miami) so I have lots of sun and my incoming water is typically 70F or higher. Any input would be appreciated
