Why cant you just let him try? Like I often say even if his experiment is a horrendous mistake learning is never a mistake. Glad you were not around Thomas Edison!It will be an experiment and nothing I tell you will matter untill you see how poorly it works.
Very cool. My plan is to place elements in my main water storage tank to keep water above freezing and help the instant water heater along by not having the water so cold when it starts heating. 5 gallons is obviously a lot less than 200 gallons but I dont need to make it hot just maintain 60 degrees or so.Well it came in today and i played with it a little. Hooked it up to two 305 watt in parallel pannels. Made open voltage of 40 volts and 15 amps. Put the 24 volt - 400 watt in a 5 gallon of water. Sun was about 2 hours before peak. Faucet water temp was 74 degrees. Checked water temp in an hour and it was 120 degrees. Forgot about it and checked again later and it was 130. It looked to top off at that temp. Dont really know how long it had been at 130 either. So all in all the 24 volt , 400 watt element worked pretty well. The thought is to possibly use it to preheat the water in the hot water heater as the lower element. I put a kw meter on the hotwater heater and will see the results in a week. After that i will replace the ac element with the dc element for a week and will check the difference. Still will have to tweak with different panel configs with volts and amps to see how far i can push this. This is straight panels no batteries or solar controller. The dc does have a thermostat on it.
Readings at 10am: PV end of cable 39.7amps 11.57 at element 9.13v ....362w output of element
Just what are you doing with this heater. It is outside with garden hose, pool heater?
