ChuckNorris
- Sep 6, 2020
- 36
I spent 2 years dreaming this up after many variations later. This is my product. I will probably never make another one of these. It was way too much work. Insanely clean wiring and design for the ultimate simplicity for my customers. I am selling this one of a kind pack to a local customer for $ 5300 Let me know what you think. This is NOT for sale on this thread. For discussion only. Admin's don't move this thread like last time. I'm not selling it here.
~16x 3.2v eve cells
~120amp overkill solar bms
~victron smart shunt
~225 pounds
~ 175amp anderson in and out connector
~100 amp dc breaker
~Steel container with rolling casters
~Custom electrical box for electronics
~BMS box can be pulled out in one yank. Only actual wires that need to be disconnected is braided bms wires.
~BMS box locks the battery into place
~Customer wiring harness and wiring channels so ALL balancing leads are on the outside of the case to make installing super easy and error free for DIY
~Steel plate at bottom as compression plate. In the event the cells need to be removed you can remove the casters at the bottom which releases the bottom metal plate to remove compression so you can remove cells in the case of swelling
~Carbon fiber wrap.
Should out to Will Prowse for all the inspiration and knowledge i needed to build this pack. After years of watching him and 100's of hours of my own research and designing. I would LOVE a simple response from Will that he saw this. It would mean a lot to me. I would love it if someone got his attention for me.
1000 watt load @ 14 hours
~16x 3.2v eve cells
~225 pounds
~100 amp dc breaker
~Carbon fiber wrap.
