Delta Pro Stuck in Standby
JLNAST
I had my refrigerator plugged in to the Delta Pro unit during a storm. The unit made a clicking sound then turned off. I disconnected it from everything and tried to turn it back on it gave an "Overload" error. It is charged to 85%. I can connect to it with the app. When I tried to power it up it beeps 3 times then goes to Standby mode. I tried pressing the reset button on the back without any effect. Outlets wont work in dc or ac.
Any remedies?
Check all your negative battery connections to be sure they are tight
Did you try the circuit breaker button? If not this might be something for warranty claim
Any remedies?
Was your DP plugged into 110v (for charging) during this storm?
