Kapow_Network
- Mar 30, 2021
- 73
Well, I almost started the headline with Dumb Question #1... nube here.
I need as much juice as possible to go into a Bluettii EP500 Pro that I bought via kickstarter (of course, anyone can easily point out that it might have been better if I bought the Ecoflow Delta or some other system that came out later, or just used a DIY Blueprint, but I needed batteries anyway. So at the price point, not just Hobotech, but the specs it seemed like Bluetti offered a lot of value. Details here
Note: important to distinguish the EP500 specs from those of the EP500Pro. So far as I know neither is available on Kickstarter anymore.
I'm also trying to pair it with 1 - 3 (depending on whether parked or moving) REC 350 TP2S72 panels (350 watts).
Basically, here is a diagram with specs:
1 - 3 panels [REC 350] with each one carrying:
... VOC 46.7 v
... VMP 38.0 v
... ISC (short circuit current) 9.40A
... Nominal power currrent 9.00 A
.... Max System voltage 1000 vdc
.... Fuse rating 20A
... IP67 junction box with bypass diodes
| - connection wires (MC4? but the panel specs say
Tonglin TL-Cable01S-F (4 mm²) (1500V)
Tonglin TL-Cable01S-FR (4 mm²) (1000V)
| - guessing these are one manufacturer's models for an MC4? And any MC4 wire / 10 awg will work to connect the panels?
I may need to rotate or move the panels a bit, so I was thinking I might need to custom cut 2 - 4 feet of wire between each panel.
*** ? Controller or other device needed here? ***
Bluetti told me an MC4 (Anderson I believe) will go into it's all in one
EP500Pro.
The specs on the EP500Pro ( from almost 2/3rds down the kickstarter page listed above) are:
PV or T500 input = 2400w max
35 - 150 vdc (looks like at 46.7 my panel meets this; but is my panel too strong for these figures below?
So I thought it had a built in controller, but now wondering if I need a step down device or perhaps I should get a different panel or set of panels ?)
12Ax2
12v / 24v, 8.2A
I'll try to also post a diagram / sketch soon in case that helps show what I'm trying to do.
Thanks in advance for any help.
BLUETTI EP500 & EP500Pro - The New Era of Home Backup Power
5100Wh LiFePO4 /1200W or 2400W MPPT Solar /Seamless UPS /240V Split Phase /6000+ Cycles /App & OTA Upgrade /100W USB-C /Charge Tesla
www.kickstarter.com
... VOC 46.7 v
... VMP 38.0 v
EP500Pro.
12Ax2
12v / 24v, 8.2A
