danphillips
- Oct 29, 2019
- 108
Please give this design a review for any mistakes / issues. I have 12 CALB cells (3p4s) to add to my existing FLA cells.
Quoted from www.zwerfcat.nl
While discharging, the lithium batteries stay above 13.0 Volt until they are almost empty. The lithium voltage is higher than the voltage of a lead-acid batttery under load, so the lead-acid battery will hardly deliver any current, if anything at all.
While charging, the voltage quickly rises to about 13.4 Volt, a voltage where the lithium batteries absorb all the available current but a too low voltage for lead-acid batteries to meaningfully charge. So the lithium batteries take up all the current until the BMS takes them offline, and only then the voltage rises enough to charge the lead-acid batteries.
