There are very few travel trailers that have a leveling system. Heck, very few of them have powered leveling jacks, but that's changing. I assumed that the OP's trailer had none of that, but it's a good question to ask.
I agree. I am seeing more and more of the newer ones having electric scissor jacks, and not full systems. But can't hurt to ask!There are very few travel trailers that have a leveling system. Heck, very few of them have powered leveling jacks, but that's changing. I assumed that the OP's trailer had none of that, but it's a good question to ask.
Updated schematic with grounding and shunt removed:
Gonna sit on it a bit before purchasing anything. The trailer is currently in storage and I can't remember, but am pretty sure that the A/C components are grounded to the frame in multiple places. I found manufacturer instructions on how to do a g-n bond in my generator.
Thanks again for the input.
Thanks for looking it over. I've got manual scissor jacks all four corners and I just use an 18V impact gun toJust did a quick skim through your thread here and only have one question: Does you trailer have a leveling system or electric/hydraulic jacks?
Very cool! I do miss it sometimes... well not optimizing for large assemblies, but parametric modeling haha. I no longer have access to a license, so I haven't figured out what program i'm going to use for this project.I also work in Solidworks for 6+ hrs a day for work, and I put my entire compartment in CAD, with all the related parts. It was quite awesome. After designing it, I was able to make all the mounting brackets, the drop floor for more space, and everything already had mounting holes and wire routing planned. Worked very well!
I've owned it for a few years and gotten a decent amount of use out of it. So far no issues ?Are you going for a champion Geno ? I've heard BAD things
Thanks for looking it over. I've got manual scissor jacks all four corners and I just use an 18V impact gun toannoy everyone within 3 mileslevel the trailer by hand.
For my personal drawings, I bought Solidworks for Makers. Its 100% solidworks, and only $100/year! Its a little complicated to get setup and how to get it open because of the stupid way they do it. I got flustered a few times, but I got it figured out. For $100/year, I couldn't complain lol.Thanks for looking it over. I've got manual scissor jacks all four corners and I just use an 18V impact gun toannoy everyone within 3 mileslevel the trailer by hand.
Not a bad deal, especially considering I wouldn't have to learn a new tool. Thanks for the tip.For my personal drawings, I bought Solidworks for Makers. Its 100% solidworks, and only $100/year! Its a little complicated to get setup and how to get it open because of the stupid way they do it. I got flustered a few times, but I got it figured out. For $100/year, I couldn't complain lol.
Ok, here's what I'm thinking then:There should only be one chassis bond.
That will cause cursing and gnashing of teeth.Ok, here's what I'm thinking then:
1. Attach the shore power in directly to the ground bar in the power distribution, which is the common ground for existing A/C and 12 V system (as it currently is, but run the hot and neutral to the new equipment.
Sounds good.2. Use Lynx negative bus bar as the shared ground reference for all the new equipment.
I think its still a ground loop with the ac ground wire.3. Green wire from Multiplus to lynx represents the chassis ground and is 1/0 or greater
Not following.4. Run single 2/0 from Lynx to existing lug across the trailer. (expensive, but lets me have single ground reference and easier than drilling new ground and running all the existing grounds there)
Ok I've thought about it....
Separate the ac ground from the dc negative busbar in ac/dc distribution panel. - done
They should be separate from each other and isolated from the frame. - Currently both bus bars in the power distribution are connected to the shared ground. Why would I want to disconnect the chassis ground from these bus bars?
The 12 volt and 24 volt dc_domains are not referenced to the chassis via the lynx busbar. - Not sure I understand. The 12V is currently referenced to frame via the shared ground (see image below)
The multiplus chassis ground lug is connected to the lynx giving a low resistance path for a dc fault inside the chassis. - done
Also keeps the chassis and ac ground and the same potential.
Also gives an ac hot to chassis fault a path back to the inverter or shore power pedestal. - Where
The idea is the lynx negative busbar is the single point of chassis reference.
I think that covers all the bases.
If anyone else wants to check my logic I would appreciate it.
The legacy DC 12V system has return wires on all circuits which go to a common 12VDC Neg Bus Bar with one exception: The legacy battery negative terminal is grounded directly to the chassis and uses the chassis to return from the 12VDC Neg Bus Bar. (As shown in that image with the floor plan).One question before we get started.
Do the legacy branch circuits have a negative wire or do they all use the chassis for return?
This all makes sense! Does the drawing look accurate now?The MP2 case grounding lug is attached to the lynx
The lynx is attached to the vehicle chassis as directly as possible with 2/0 awg wire, 2/0 wire is expensive.
The ac out wiring(hot, neutral and ground) to the ac distribution panel is all 10 awg, same as the ac in.
The dc negative between the lynx and the dc distribution busbar in the panel only needs to be 6 awg.
The ac grounding busbar and the dc negative busbar in the legacy panel should be isolated from each other and from the vehicle chassis.
Summary:
The only connection to the vehicle chassis is 2/0 awg directly off of the lynx.
The only connection between the ac and dc domains is the MP2 case grounding lug.
Hope that is clear.
