KingAdeCode
As a DIY solar installer, I've been following this forum for quite some time. I currently have a 24v system consisting of two flooded batteries, a MUST 80a MPPT controller, and a Yohako 3.5kva inverter; I'm looking to upgrade to an AIO inverter that is both efficient and durable; I'm not going completely off-grid because my budget is tight right now. I'm on the verge of deciding whether to go with the Deye 6kw or the Growatt SPF 6k. The Deye is x2 the price of the Growatt. I really need advise from people who have used both or any of the inverters.
I have purchased:
Looking forward to buy:
Here are my concerns:
I have purchased:
- 10 x Jinko NEO 555watts mono-facial Panel
- 1 x Deye 6k (price: ₦1,600,000) or 1 x Growatt SPF 6k ES (price: ₦840,000)
- 1 x Pylontech 5.12kw UF5000 at ₦2,032,000
- Since the Growatt SPF 6k ES is an off-grid inverter, will it be suitable in terms of grid support, which is one of the features I need most?
- What other benefit (aside from selling to the grid) will I get if I go for the expensive Deye 6kw?
- Can the Growatt use Grid to charge the battery while I supply load from the battery at the same time without going into bypass mode, as stated on this thread? and this particular comment
- Is there currently a solution for the problem that causes Growatt to stop charging even when there is enough power coming from the PV and instead use the battery to 90% before starting up again?
- The Pylontech UF battery is built with 16 cells. I haven't seen people's reviews about it
