Hello guys, I have a quick question. In the case of the Deye 8KW hybrid inverter(SUN-8K-SG01LP1). It has two mppts and each can accept two strings of solar panels(attached spec sheet). Basically it accepts 26A per each mppt thus only 13A per string as stated by engineer from Deye. Is it possible to use 17A panels (Trina 660w) with condition that I only use one string per mppt. Are the mppt strings just connected in parallel or does each has its own current limiter to 13A.
Thanks for the help!
