Deye Firmware Tracker Thread
themizz
tinkering
Philadelphia
Hi,
I'd like to start a thread tracking which firmware versions Deye users are using. Please specify:
1) HMI (LCD) and Main (Control Board) Versions
2) Original firmware or upgraded
3) Date of upgrade
4) Inverter Model
5) Split Phase? (for Caribbean use, for example)
6) Feature enhancements/bugs or other notes.
Deye SUN-8K-SG01LP1-US split phase
If your inverter is on SOLARMAN and you email support with your serial number and ask to be upgraded, they’ll upgrade you at some point, but your inverter will reboot and you’ll loose power for a few minutes if you’re using it as an UPS power source.
@copec, can you specify the model you are using and if it's split phase or not?
- HMI 0000-c358 / Main 0-3374-1515
- Upgrade requested to Deye. Previously c356 at time of purchase
- upgraded 11 July 2022 (Deye did it remotely, inverter shut down < 10 minutes ...)
- 5k EU
- single phase 230v
- upgrade requested to solve an issue on time of use. Inverter didn't follow charge schedule in 1 particular time laps, everything else working as intended
HMI: 0000-C3FC
Main: 0-3373-1515
- Upgrade provided by Deye 25/07/2022 (original firmware c358)
- Upgrade completed locally with file provided from Deye
- SUN-5K-SG04-LP1-AU
- Single phase 230V
- original firmware didn't include grid settings for Australia/New Zealand.
Have since noticed some bugs on the grid settings pages 'Grid Setting/P(Q) P(F)' & 'Grid Setting/V(W) V(Q)' where the units seem to be % when they should be V.
SUN-5K-SG03-LP1-EU
Update requested and updated to latest today 3/10/2022 (Above screenshot is after the update)
I've also been updated to C35C after I had some issues with parallel communications between inverters on C3FC
Updated on 15th September 22
Aren't Deye publishing official firmware releases with official release notes on an official release channel?
(Not actual screenshot. drew on paper, then reproduced using MS Paint)
No idea what the middle part means.
And then on the next page (Grid Set3), the top liner:
Over voltage U>(10 min. running mean) 0.0V
What does that line mean?
The middle section are the parameters that the grid needs to fall into after the inverter will reconnect to the grid. I.e it has tripped for some reason (low frequency for example).
So after a trip the inverter will wait for 'reconnect time'. Then confirm the voltage and frequency are within the limits on the middle section of that screen. Then slowly ramp up the power over the time specified in 'reconnect ramp rate'.
And the overvoltage 10min average is fairly self explanatory. If the average grid voltage is above that value for 10mins, the inverter will trip off (disconnect from the grid)
Based on the settings you have there, these are disabled I guess.
Here are my settings (for new zealand)
If I am not mistaken this Over voltage U is basically similar to having this:
ie: If Grid >249V and <265V for >600s, Deye will Disconnect.
Why have to add a separate entry?
This middle part of GridSet2 appears similar to the previous version GridSet3 then...
I suspect they are slightly different.
The top value uses a running mean, whereas I suspect the rest of the numbers on this page use a time delay. I.e the grid voltage has to exceed that value for that time.
I received my inverters with this firmware pretty much, so I never really saw what it was like before.
