Onapt
Hello, can you share this file, and can you share what type has your invertor?
@Sleeper85
Has the MPPT scan been working without any problems for you since the time you have used it?
Havent seen it in mine yet, firmware was updated in juneDoes anyone know or could anyone check if this MPPT scan feature is also available in the Deye 12K-SG04LP3 inverter?
I have tried to update this github repo with some of the latest info from this thread. It seems, almost all the files that people have been sent by Deye can be downloaded from their server, i.e http://47.254.36.66/0_5407_1/MCU1-SG-Ver0000-C36E-CK.bin
I have successfully updated my 5K-SG04 inverters from both MCU1 and MCU2 bin files from this server. The trick is working out what the correct file names are for your inverter. To do that, you can either ask them to send the files to you, or you can run something like squid proxy on your router to log the web address that your inverter pulls the firmware from when Deye updates your firmware remotely.
If you want to fork my repo (which I forked from https://github.com/dasrecht/deye-firmware) and tidy it up, please feel free, as I don't have much time to spend on it. It might be worth getting rid of all the microinverter firmwares and info and have one repo just for Hybrid inverters.
Here's some example URLs you can use to pull files.
# Deye Hybrid Inverters HMI Firmware (MCU1)
# Deye Hybrid Inverters Main Firmware (MCU2)
http://47.254.36.66/0_5407_1/SG_5K_MCU2_V3387-NR.bin ##(SUN-5K-SG04LP1-AU)
http://47.254.36.66/0_5407_1/SG_6K_MCU2_V4386-NR.bin ##(SUN-6K-SG03LP1-EU)
http://47.254.36.66/0_5407_1/MCU2_5227US_NC_NR8K59V.bin ##(SUN-8K-SG01LP1-??)
http://47.254.36.66/0_5407_1/MCU2_6027US_NC_NR8K59V.bin ##(SUN-8K-SG01LP1-??)
Respect !I have tried to update this github repo with some of the latest info from this thread.
Apparently the 2 programs are equivalent, both work fine on the inverter, the changes seen are the default configurations. The 6027 will setup the EU Grid standar as default and the 5227 will put US Grid standard. They may have more internal different things but so far all screens and setting are the same.
Are you planning to host the 12k 3 phase firmware too ?FYI concerning 8K firmware.
5xxx = SUN-8K-SG01LP1-US
6xxx = SUN-8K-SG01LP1-EU
But according to @soca90 tests it's possible to install a 5xxx firmware on an EU version and vice versa.
Could you clarify for me which version is the latest one?Thanks @cods4 for finding the Deye server address
For those who want it, you can download the latest firmware for SG 6K with the links below (haven't tried it myself yet) :
http://47.254.36.66/0_5407_1/SG_6K_MCU2_V4387-NR.bin
Unfortunately not everything is deposited on this server.
I attach my MCU1 firmware pack with the C370 as well as the update procedure.
Have a nice day![]()
Or
MCU1-SG-Ver0000-C370-CK.bin
Thanks a lot.
you can upload itFor Deye 8k US this is the latest one.
MCU1-SG-Ver0000-C372-CK.bin
When a new firmware is release Deye remove the old one from the server.
