Rossen-Javor
Hello everyone!
Deye inverter 12KW SUN-12K-SG04LP3-EU - 2 units, working in parallel, with an EV Li-Po battery pack of 63.6 kWh, total electric charge: 1320Ah, operating voltage of the batteries according to the BMS in the range from 49.32V to 39.84V, after another firmware update (made by Deye without anyone asking me...on March 07, 2025) the discharge of the batteries was limited to 44V = 54% of the battery capacity. Before the update, the inverters discharged the batteries to 40V.
In addition, the option to enter data about when the batteries are empty in volts has disappeared in the inverter menu - the "Batt empty V" cell is no longer there. This option has also disappeared from the Deye cloud platform and Deye solar me.
I have written several reports to Deye support, to all possible emails, but no one responds...
This situation is absurd, because on the website, regarding the technical characteristics of these inverters, the following is written: "Battery Compatibility: Inverters work effectively with both lead-acid and lithium-ion batteries, accommodating a voltage range of 40-60 V, with a self-adjusting battery management system (BMS)." The same operating range of batteries with which these inverters can work effectively (40-60 V) is also marked on the stickers of the inverters themselves.
For me, the problem arose after the update HMI: Ver 1001-C-04D, MAIN: Ver 2006-1151-1807
I have friends who have other models of Deya inverters and in their menus, as well as in online platforms, the cell "Batt empty V" still exists (I attach a photo).
If you have the same model of inverters as mine, can you share if the above setting options still exist for you?
Has anyone of you encountered this problem and found a solution?
