robby
Photon Vampire
- May 1, 2021
- 4,119
Weight is only a factor up until a point. You cannot compare the weight of a low freq inverter with a transformer less high freq inverter. If you want to seperate out the two catagories then weight has some bearing but it's certainly not the biggest factor. I like the idea of passive cooling and that it where the weight in a high freq inverter comes from. On the other hand Fans can work really well and most units can detect Fan issues and throttle back and alert you. Fans are also cheap and easy to keep spares in your supply drawer.I would not personally buy either of these inverters. This will be a bit snarky, but I have a point: Inverters are not sold by what features they have or how much energy they can handle.. they are sold by weight... period.. end of story.
The reigning undisputed king of inverters are the SMA Sunny Island units. For 120 volts at 6000 watts, the unit weighs 139 lbs.. for just one of them. You need two of them (278 lbs) to make a 120/240 split phase system at 12kW.
That said, you can make a single unit produce 6kW at 120/240 with a transformer.. at 139 lbs.
The Outback Radian 8048 (8kW unit), in my opinion and many others, would be the next best unit on the market, and it weighs 125 lbs.
I own two Sunny Island units and a Radian as well.
After these two models, the quality goes down hill.. and when I see 6000 to 8000 watt inverters being sold and they only weight 70 lbs and are packed with all kinds of fancy features, I tend to run away..
I think the difference between 70 and 130+ pounds is how much abuse the unit can take and if it will still be running in ten or fifteen years.
You can buy a brand new SMA Sunny Island (with 10yr warranty) on ebay today for $2500..
That's just my opinion.
That might be a valid point if it was not for the fact that those "Fancy" features are very useful and make the unit much more efficient without user intervention. Also nobody seems to be having an issue with their 70lb units so it seems your getting reliability and fancy features.
I had the Money to go SMA or Sol-Ark but at the end of the day a full micro grid SMA system was more expensive and a lot more bulky than the Sol-Ark and I just could not see any real advantage to justify the cost.
I will admit that SMA is probably the best Inverter but they do not have an all in one solution to go against against the current crop of Hybrid models. Also SMA tech support is absolutely terrible.
