MurphyGuy
It just needs a bigger hammer
- May 20, 2020
- 4,129
It really depends on how you use the system. AC Coupled systems are far more efficient when the power is being used, while DC coupled systems are more efficient at charging batteries.From my perspective, the Sunny Island isn't an All-in-One solution that makes the other hybrids standout, even at their much higher price points. The SI also appears to be primarily designed for AC coupling, where as the other AIO's are mostly DC coupled systems (w/ limited AC coupling in Sol-Ark's case).
I'm not experienced enough to critique Sol-Arks's comparison chart to other systems. Even though the attached chart is sol-ark marketing material, I have yet to see anyone refute the listed data...
It has shows that the SMA SI systems (2 x 4548) have some pretty poor conversion efficiencies to batteries.
In our case, we are AC Coupled and the solar array is capable of making far more power than the batteries need or the house normally uses. With this in mind, we run all our power hogs during the day when the sun is out. This method is more efficient than DC coupling.
However, if you were at work all day and charging a battery bank while you're gone, then the DC coupling would be more efficient because there's no AC conversion needed.
If you're using Lithium batteries, the AC coupling is a better system. With DC coupled systems, the charge controller reads battery voltage to make decisions.. when the battery is full, it waits until the battery drains to start charging again.
With AC coupling, the energy never even sees the battery bank, it goes straight from the grid inverter into your loads.
Why does this matter? It doesn't with a lead acid battery.. not much anyhow. but with lithium, that short cycling causes battery wear when DC coupled.. but not so with AC Coupling.
I hooked up my neighbor with a Sunny Island and DC coupling through a Victron charge controller.. His type of energy use makes more sense for the DC coupling system because of the way he uses power and the ratio of his array size to his battery bank.. It all makes a difference, and while none of it is "do or die", it does add up..
Frequency Shift Power Control is an amazing technology to watch in real time.. seeing the inverters throttle the array to exactly match the house loads is just so graceful and cool to watch.
