Hello Guys i need your help
i'm facing the a problem i can't fully charge my battery and i have 2 batteries connected to each other if i make the RS485 between the batteries the inverter starts beeping and its show SOC: 100% than SOC: 0% in RED.
if i connect 1 battery to the inverter VIA CAN connation everything runs normal BUT the battery charges only till 99%
i need your feedback on how you solved your problem.
attached the video on how the inverter is behaving when its connected with 2 batteries ,also the pic1 is the BMS when the 2 batteries are connected and pic 2 is the BMS with 1 connected battery.
and the voltage of the batteries (pic 3 and pic 4)
