mrzed001
Voice of reason
Good In the AC out part did you use a relay for off-grid connecting N+PE ?System is now exactly like a TN-C-S MEN system.
They have internal CT too. Maybe on that setting ?The Deye are definitely both or none. I can sort of understand because everything is divide by two in the master and sent to the slave. The grid CT is only connected to the master so the slave would not work if not communicating with the master. Might have been possible for the master to keep going if the slave was lost but more complex logic. If you change certain settings in one they are automatically changed in the other.
You know things always happen when you are not home.
If you are in a one week holiday abroad and your home power system stops ... thats a mood killer
That is good news. I like itYes they say SunSynk, Deye, Sol-Ark will work and seems like they have the same interaface
