Did I Get Ripped Off?
Ralo
I purchased 30 used Sunpower E-Series Commercial Solar Panels E20-435-COM from ebay and they are advertisted to be working at 98% of out of the box capacity. However, when I tested several of them today in clear, direct sunlight, I'm only getting 80-85% of the rated 435w output. Did I get ripped off?
At first, I was shocked and very disappointed at such a low output. I paid up for these panel compared to other offerings on eBay and considering the wording of the ad, I thought was expecting more. Now to be fair, on a percentage basis, they did do slightly better than my existing 265w panels, but I was really expecting over 400 watt in direct sunlight...especially since it was so cold here today (near freezing).
So am I expecting too much from these panels or was I straight up deceived by the seller? Please chime in...
The pictures below show the readings from the charge controller and the position of the sun at the start of the testing. The result got worse the more I tested so that is likely related to the sun moving farther west. I guess I really can't complain since they are outperforming my existing panels. But I was hoping for that 98% claim. Maybe when the sun is higher.
RCinFLA
Photon Sorcerer
If in northern hemisphere, it is winter time with sun only reaching low angles above horizon. Lower to horizon sun means more atmospheric losses.
I highly doubt anyone can measure a 98% of rating output on a panel accurately.
sunshine_eggo
Happy Breffast!
USA
Probably not.
Have you confirmed that the panels are receiving 1000W/m^w of insolation? If not, you can't make any objective conclusions whatsoever.
Assuming you are in the northern hemisphere by how low the sun is in the sky, you're about 30 days past the WORST solar day in the northern hemisphere (winter solstice).
Direct sunlight in Winter has inherently less total energy available.
Blatantly.
And/Or because the cells were heating from solar and current flow. It might have been freezing, but those cells were warm.
Maybe around the Summer Solstice.
sunshine
Maybe just a reality check as to the % difference expected between 2nd hand 435w and 2nd hand 265w panels.
80-85% seems ok to me, It would be interesting to know what your 265w panels are getting under the same test.
MurphyGuy
It just needs a bigger hammer
I can tell by looking at the picture of your house that 80 to 85% is pretty spot on.. I'm guessing you're somewhere around the middle of the USA in latitude? Maybe Kentucky, Iowa or a bit more south?
When the sun is directly overhead and its 50°F outside, try it again and I bet you get full power.
Ralo
They were producing around 80%.
Bud Martin
Photon Sorcerer
So do you see the Power go up if you try to charge the drained battery or with heavy loads running?
The battery is at 58.50V, that battery looks to be full.
Ralo
That's not my house. That's next door. See my house below. My idea of a tiny house.
I will be covering that roof with solar panels. I had to raise the building to get that RV under there.
Ralo
It still wasn't full. At the end of the day it was only up to 85%.
The voltage will go down if I put a load on it. That installation wasn't under load at all. It had just been charging all day.
Bud Martin
Photon Sorcerer
According to the Voltage charge 55.20V is 99.50% SOC, 58.40V is 100%. 85% SOC is up there already, as battery getting fuller, the power draw from the panels will drop, that is why I suggest you to turn on heavy loads so it will draw more power from the panels.
So if you turn on heavy loads, you do not see the Wattage goes up? You should see charging current goes up.
Ralo
Not from that set of panels. It was still bulk charging. Hadn’t even made it to absorb. Under paneled. That’s why I’m adding more. That trailer has 2.6k of PV charging 1040ah of batteries. It usually takes 3 days to fully charge those batteries, and that’s with direct sunlight and no loads. The fact that we very seldom get clear skies here and the fact that the trailers are under paneled anyway is the reason I’m adding so many panels. I’m in northwest Louisiana.
MurphyGuy
My point was that sun is way down low on the horizon and the energy has to pass through a whole lot of atmosphere before it gets to your panels.
No panel will produce full power under those conditions.. so if you're getting 80 to 85, then your panels are probably in great shape.
Ralo
Makes sense. Thanks!
Ralo
I did some more testing on those SunPower solar panels, this time in overcast conditions. They are commercial panels and are supposed to be more efficient than conventional panels. Well, I'm sorry to say that they performed no better than my existing Talesun TP660P 265 watt panels. Both the Talesun and the put out 10-12% off their rated power during overcast conditions. These are the conditions I'd hope that the SunPower panels would show their superiority. But nope, that are as mediocre as the Talesuns.
I paid extra for the SunPower panels. $.38 per watt. I could have gotten conventional panels for $.23 per watt, so I paid almost twice as much as I had to. Oh well, you win some and you lose some.
I've attached pictures of my results. I'm too lazy right now to label the images, but you should be about to tell which panels are being tested by the calculations above them. Maybe their performance is why they were uninstalled and sold on ebay.
Bud Martin
Photon Sorcerer
Picture #2 shows PV 146.3V, 294W.
Picture #3 shows 54.8V, 46W
Are they SunPower readings?
sunshine_eggo
Happy Breffast!
USA
Why you would expect them to perform differently? A panel's performance is dictated by the amount of energy falling on its surface and its efficiency. Most panels are around 20% efficient. Even if they are 21% efficient, that's only 5% more efficient than 20%. If the solar conditions are such that they are only getting 10% intensity, the more efficient panel will only yield another 0.1% of rated power.
Mediocre? Those are great results. There is no such thing as magic. Panels can't create energy from nothing. Cloudlight has substantially less energy than sunlight.
Nobody to blame but you. You made the purchase based on hope and assumptions. Guess what? Clouds make for shit solar on ALL panels.
You have no basis for this claim. It's based on your unrealistic expectations. All evidence presented indicates they are performing as they should. You can't claim shenanigans on the part of others when you have unrealistic expectations.
$0.38/Watt is a great price. Take the win.
And stop taking seductive pictures from your bed! :p
Ralo
This is why I expected them to perform better. SunPower claims 20% effiency. Talesun only claims 16%. Yet they perform the same.
Oh, and if you think that picture is seductive, you are playing for the wrong team buddy. So keep your fantasies to yourself.
Ralo
Picture 1502 is a single 435w SunPower panel. Picture 1501 is 10 - 265w Talesun panels.
