Hi guys.. I'm a sailboat cruiser interested in opinions on whether or not to buy a bunch of panels or stick with my generator and rebank with liFePo4.
Here is the current set up:
Start bank is 4 12v agms run series parallel to make 24v
House bank 8 200Ah 12v series parallel victron agms for 24v bank loads and also a 225 Ah Victron 12v 8d charged off a dc to dc 24v to 12v converter for the 12v loads
55 amp 24v alt external reg for start bank , 172amp external reg 24v alt for house bank ... Perkins 225 hp turbo diesel main
24v 24 amp alt external reg alt for start bank from a 20Kw 120/240 single phase Northern Lights generator for start bank
2 100 amp chargers 24v
1 120v 3000watt inverter
1 240v 3000 watt inverter --both stand alone.
Parallel switch between house and start bank.
Batts are 4 years old and in good shape. Very few cycles ...
(I burn 1.73 gph diesel with the gen and it takes about 6 to 8 hours to bring the Agms up to 100% from a 50% dod.)
Normal loads while cruising include a large hot water heater, two cold plate fridges and one freezer, water pumps , watermaker, starlink and various other loads such as TV, computers ,nav gear , dive compressor, radar and induction counter top cooking.
Large 70' sailboat 120/240 ac ,12/24v dc loads.
The question is... should I replace the AGM batts with lithium and charge dc-dc with the 20kw gen ? Or should I put a large solar array and keep the AGMs charged up with that and forego the lithium batts until the AGMs are shot.
I'm thinking that (with my limited knowledge) the large cap Alt, the rapidly of the lithium charging and the 80% depth of discharge ,I may be smarter to just buy and gen charge a new lithium bank and forget about the cost of panels and building a double set of arches to hold a bunch of 550watt bifacial panels. I have the room for at least 6 of these massive panels
What would be the opinions of knowledgeable people on the forum who can help me decide which way to go?
I lived on solar panels/agms with no issue and a 4kw gen on my smaller 45ft boat but that was before Ithe option of LiFePo4 batteries... so I'm really not sure how to play this.
