4mm ID is what fits the barb on the heater itself and fuel pump but some heaters use hard nylon 2mm ID, 4 mm OD line using rubber 4mm ID line for connections.I'd sure like to know so I can add another fuel tank. I sure like it and it runs very well....so much better than those electric heaters
The heaters run perfectly fine with the soft 4mm line. The fuel doesn't need to be "spritz" in. I have heaters using both types for 4 years. The hard nylon line is more resistant to heat damage and kinks. David McLuckie demonstrated that on his YouTube channel if you're interested.The line to the pump just needs to flow. I think I am running 3/16" brake line and 1/4" rubber.
But the line from the pump to the heater does matter. That hard plastic (Nylon?) that comes with it is what should be used. Don't downgrade to rubber. The heater needs the rigid wall for the pulse off the pump to hit the burn chamber. Need the hit to spritz the fuel in and get a good burn. The van crowd is full of people who tried using a better hose, that softens the pulse, and doesn't run.
6mm will be too big.Thanks folks for all the answers, I've got some 6mm coming I hope it works.
it is 4 kw in reality, I use these for a lot of spot heating in the house and to keep the upstairs warm.I have a vevor model XMZ-L-D1 (D3) 8kw heater.
Does anyone know the size of the fuel line?
that is the superior line to use4mm ID is what fits the barb on the heater itself and fuel pump but some heaters use hard nylon 2mm ID, 4 mm OD line using rubber 4mm ID line for connections.
excellent channel to learn about these heaters. I strongly recommend watching it!The heaters run perfectly fine with the soft 4mm line. The fuel doesn't need to be "spritz" in. I have heaters using both types for 4 years. The hard nylon line is more resistant to heat damage and kinks. David McLuckie demonstrated that on his YouTube channel if you're interested.
get some petrol warm the pumps up really good then tick them manually to get the petrol flowing in em, you can clean out the pump this way a lot of the times.Last week while checking out my heater before winter the fuel pump failed. I removed it and tried to free it with some carb cleaner but no luck. I replaced it with a spare but it failed after a few minutes. I noticed the diesel fuel felt oddly sticky on my fingers. Turns out I had temporarily stored several gallons of diesel in a plastic bucket and something leached out of the plastic that made it sticky and seized the fuel pumps. Fresh diesel and a new pump solved the problem.
I do use a 12v battery to test the pumps. Tried gasoline, ethanol, isopropyl alcohol, lighter fluid, kerosene, WD40, 3 in 1 oil. Haven't tried acetone yet. Thermite might work. No big deal, I have spares. Mainly wanted to warn others.get some petrol warm the pumps up really good then tick them manually to get the petrol flowing in em, you can clean out the pump this way a lot of the times.
Carb cleaner isn't the right solvent for plasticizers.
Running Kerosene through it after really cleans them up.
ya it needs to be hot as you can practically get it to loosen up the polymers, if that fails then ya they're glued.I do test the pumps with a 12v battery. Tried
