Hi All,
I have been a reader on this forum for about 2 years and taken the plunge in setting up my own system (with questionable success).
I am currently using a Growatt SPF 5000 es. I have 3x Delongtop 51.2v 200ah batters connected in paralell (no bus bar) and have 2 main challanges.
1) When connecting the RS485 and using Lith (L02) the charging seems to be capped at about 500w. On USE 2 it will run at 2500w+ This is basically what my solar panels are able to produce as I am running a single string of Jinko 440w x 7. I have a second string ready to install but working one thing at a time. (we are only running a fridge at the moment).
When I use the Lith setting I get very arcuate % reading (e.g 94% etc) so it appears to be communicate. USE2 on the other hand gives the 25% groups (e.g 50%,75%, 100% only).
Does anyone have any suggestions as to why my BMS might be capping the amps in and what I might do about it?
2) overnight there seems to be a fair amount of discharge. (estimate 5.0kw) the. I am getting uneven battery discharge . The odd thing is it is a different battery each night.
Night 1 - battery 1 (68%), battery 2 (74%) battery 3 (74%)
Night 2 - battery 1 (92%), battery 2 (74%) battery 3 (92%)
Night 3 - battery 1 (74%), battery 2 (97%) battery 3 (74%)
Night 4 - battery 1 (54%), battery 2 (90%) battery 3 (90%)
I understand that generally the discharge should be consistent. The batteries are all brand new (just installed in the last week).
Should I be concerned and if so what should I be doing?
