In my case the three panels will be connected in parallel. The panel wires will all go to one homemade combiner box on the roof with all negative on one grounding bar and all positive on another grounding bar. All three positive panel wires will be fused with 20A inline fuses. A 6 AWG wire from the positive grounding bar and a 6 AWG wire from negative grounding bar will run from the combiner box to the inside of the van to a 63A breaker. Does it matter if the panel wires of one panel are longer or shorter than the panel wires of the other panels? Can I cut off the MC4 connectors on the panel wires to connect to the grounding bars? Can I add extension wires to some panel wires and skip others? Any help is appreciated. I'm trying to neaten up the top of the van and get the combiner box finished.
