TheGoldenPanda
- Nov 10, 2020
- 5
Due to limited roof space and shape, I am planning to install two different sizes of solar panels on the RV.
The first one is a 255W CanadianSolar CS69-255P, which has a 30.2V operating voltage, 8.43A operating current while VoC is 37.4 V, short circuit current is 9A.
The second one is a 100W Rich Solar RS-P100, which has 18.5V voltage, 5.41A operating current, Voc is 22.6V, the short circuit is 5.86A.
The panels will be connected in series and the travel distance is about 12 feet to the MPTT.
The MPTT is Renogy ROVER LI 40 AMP MPPT SOLAR CHARGE CONTROLLER, (Max Solar Input Voltage: 100VDC)
The batteries are two Renogy 100 AMP Lithium batteries.
I am within the limit of the MPTT but would like to understand the limitations of mix-size panels. Almost every system I saw uses the same size panels. Any specific reasons for that?
