Thanks for the comments thus far. I should've mentioned that I do intend to use T Class fuses for the batteries as my main circuit protection. I do however need a switch and like the practicality of the DIN rail setup. The DIN rail breaker would act as my main battery switch and because it's a breaker, will also add some redundant protection but it's primary use will be as a switch. I guess I can use a 125A 2 pole breaker and run +ve polarity through both poles to get the 250A but I like the idea of a main switch being able to disconnect both +ve and -ve terminals. Now a 4 pole DIN rail breaker would be sweet but haven't been able to find any of those in 125A sizes. I'm building 2x 3p16s batteries using 280ah lifepo4 3.2v cells. Each battery by itself must be able run the load for the entire house and charge the EV in the event that one of the batteries need to be offline for some reason.
