Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,508
What I would like is a 4 panel microinverter like APSystems QS1 to be instructed to operate by the grid, but not backfeed the grid. I just want to use it to feed the bottom element of my hot water tank. Cheap simple reliable and now it's AC that won't burn up my hot water tank thermostat.
Preventing the microinverter form backfeeding the grid made me think of diodes. Then I found this.
Anyone see this engineer team working on the ACdiode?I don't think it accomplishes what I want, but it seems like that would be cool.
Kind of silly. Something to be installed in the circuit to make sure it only backfeeds the grid, doesn't ever draw power. Just so you can plug a GT inverter into an electric outlet rather than providing a dedicated circuit.
As for his wireless disconnect - if its battery is dead, the panic button won't work. For lineman safety a visible blade disconnect is best.
PV inverters with MPPT have an algorithm to adjust current draw up and down in order to extract the most power. Ideally they could be informed how much power is flowing out to the grid, so they could adjust to maintain zero W maximum export. With micro inverters, another option would be to knock them offline one at a time, removing about 300W production at a time.
Simplest for your situation, connect an appropriate wattage of inverters to the terminals of the heating element. When thermostat opens, inverter drops off line. To avoid use of grid power at night, enable with timer or photocell.
