Sure. It means I cut the wires and crimped on ring terminals to the solar wires to attach to the shunt and the water heater terminals. It’s the simplest method of connecting panels to shunt (to measure current) and directly to water heater element. In the future version there will also be a DcSSR to interrupt the circuit when the water tank reaches set max temp.
@efficientPV I guess my point in all this is every different application with its criteria and trade offs have its ideal set up. after many years in high end industrial automation and computer control, I enjoy dead simple reliable set ups with minimal fancy expensive parts that could fail and that I would have to maintain. engineer and match compononts to natively work in their ideal way. A trick I learned as a Porsche mechanic at a young age. They were often far simpler than competitors cars yet worked better by careful design. my application doesn’t have space or shade issue beyond clouds, it does have an issue of fixing and replacing components in a far away land on a mountain without an address where such parts don’t exist. My overpaneling is cheaper than the mppt controllers I would need if I look at it that way, also less to break or replace potentially 1-3 times over the life of the panels, a cost I consider to be important. I may one day get another mppt controller and side by side it in the same water tank with data loggers just for giggles, others have done it and I’ve seen much variance in results.
the next setup I’m building does away with most of the panels and uses a new hydro system I’m developing that is easy to deploy in shallow stream applications and fully fault tolerant of all the normal pitfalls and maintenance.
half my distribution set up is 24vdc so the nice inverter I have can be turned off much of the time. Yes I have line losses and less available power, but for lights and fans and our cold room it all runs without an inverter, and the cheap surplus panels cover that loss with minimal one time expenditure. I expect I can reduce inverter time by 75%, potentially extending its life somewhat before the capacitors degrade over time And render it useless.
thanks for the data, I don’t fully follow if that is theoretical or your own test results, but my tests showed 85% of rated output in hot 10+ years old panels in good sun, to 12% of rated output in full thick cloud cover. Without the side by side to equalize all variables, it’s hard to quantify The mppt difference. I didn’t get out the light meter and record irradience, though I likely should have, this was more a quick test of heater elements and panels as a set.
