houseofancients
Solar Wizard
thanks for you extended explatiin, however, this is not from the techluck guy.I forgot to talk about the Loadmaster. It is a design made by a software guy and some of his claims are a little iffy. I don't think it works as well as he says because he hasn't really tested it, just made guesses. Rather than losses in heat, it might not be able to transfer all the power the panels are capable of creating. Analysis of the AC component of the input would be needed. Solar panels are current sources. Panel current changes over a short period of time indicate the circuit is not able to store or use all the power a panel can create. The techluck claimed "97% (pass thru)" which is saying when it is not actually functioning at full power. Nothing was ever said about 50% panel power efficiency or any other range. It has three capacitors the size of your pinkie to store energy and provide all that current to the heating element. I just wonder how long those can last running all day for years being rated at .58A. Internal heating will dry them out. The internal welds of a capacitor are the weakest part. Often these are just a crimp. Repeated current spikes can cause them to fail. The standard rating for capacitors at temperature is 4,000 hours. Physical size and current rating of capacitors does matter. Sure would like to see a thermal scan of those at 50% power. There are differences in design that mean more to me than others. All these designs should work well enough to gain extra power over direct connect. The techluck which might never appear again had a severe weakness in the power supply making prone to extreme failure from a near lightning strike. I worked on
one and the only semiconductor on the board that didn't fail was the reverse voltage protect diode. For that owner it was a total loss. The ACTii solved this issue by making the power supply a seperate item. Really nice small packaging which makes it cheap to ship. Even though the photo boost module may have some length of life issues because of size, these would be easy to repair and make even more robust. Current is limited to 8A because it is made for a european marker where water heaters are smaller and lower wattage. I designed my board for 10A and that is only limited by the capacitor bank for convenient physical board size. The ACTii uses a fan because of its small packaging. Fans are always a failure point.
I use two FET in parallel which reduces heat by four times that of just one. In normal operation there is no noticible heat rise. The techluck also is 8A and uses a IGBT which has a high saturation voltage causing 15W of heat. Unknown if ACTii uses IGBT or FET.
Those with small camps don't realize that they can add hot water with a very minimal investment using only excess power from their existing array. A small array will possibly need only one or two extra panels. No need for for a battery or increase charge controller or inverter capacity. A common 6 gallon 120V water heater doesn't need the element changed and can heat water with only one KWH of energy a day. I use a 50L (13 gallon) tank from China that was only $150 shipped. It meets my needs and I have a dishwasher. Cheap, but needs extra insulation to make it effective. I gave up my propane heater years ago. I was refilling several tanks each summer. Waking up and having hot water at the sink really changes the camping experience and it costs next to nothing. This idea just has not gained acceptance as this group are usually beginners. You do need to use an array of 60-90V and they are usually battery voltage systems.
The ACTii is capable of operating in two modes. Full MPPT in a stand alone system or as a fixed voltage power diverter. The fixed mode has to be used when in parallel with a charge controller as two MPPT would fight each other. The voltage can be ajjusted seasonaly to account for temperature. My board has an external temp sensor that can be attached to a panel or a small square of metal exposed to approximately the same sun conditions. This calculates the natural power point.I was amazed at how many want to have stand alone hot water systems which to me seems very wasteful. Any successful PV system has to have excess power to recover from bad days. Why waste that power. These systems are amazing to see operate
and once you have used one would never be without one. The picture below is a half hour graph of my garage system. It uses only excess power not used by the house system and the house water heater. This 40 gallon water heater in the garage is only for the laundry and only hot water is feed into the cold inlet of the machine so all cycles use hot water.
This is a 60V array and at temperature the MPPT ideal voltage should be about 57V. This parallel array has a lot of shading and you'll see it drops to 44V at the very end, likely the refrigerator has turned on. I set the fixed voltage (green trace) higher to insure the house systems have priority. The garage also has two panels facing east and the distance to the house systems
is about 125 feet. The higher voltage insures more power goes to the house in the morning. I could be more agressive, but I get adequate hot water as it is. The dips are from clouds and/or demands on the house MPPT charge controller. Peaks above 61V are because the two 5500W elements in parallel can not take all the excess power available. Since it peaks out at less than 5A, the upper thermostat has opened up leaving just one element. Again I could be more aggressive and replace the heater elements with lower resistance ones. The clothes come out of rinse cycle steaming so why bother. I have a LG front loader and these are notorious for the mold problem. The detergent dispenser is always spotless. At home I have the same machine and have to pull the dispenser apart and clean mold out of it periodically. I should do full hot water at home. Blue trace is the element current. Yellow is the heater power. Notice given varying cloud conditions in this half hour view excess power is instantly delivered to the water heater or removed. It makes this decision up to 100 times a second. The washer in the garage also runs off these panels with no battery. When the washer goes into a low current fill cycle, excess power goes back to heating water. Free laundry is pretty neat although it has now become my responsibility to do it. In the event of a large cloud, the washer will stop. I'm generally out in the garage working so that isn't a problem. Just restart it when the cloud passes. That doesn't happen often. We line dry and only do laundry on really nice days. Last picture is the laundry system in the garage. You are not seeing things! Those are jumper cables connected to the water heater. The 10A pulses are ideal for desulfating a lead battery. Battery is in series with heater element. I just clip them together when I don't have a battery. I've been picking them up at the town recycling and experimenting with restoration. Our town has a lot of people who ignore batteries over winter and just buy new ones. Been lucky, can't save them all.
Tall tanks are really the way to go. The top 15 gallons heats quickly and the lower section acts as a pre heater. This stratified heating method has drawn the attention of adaptive control builders as a way to economize tank performance. Lower tank heat loss drops to almost nothing due to temperatures not much more than ambient. Larger 40 gallon tanks are almost the same cost as less popular small tanks.
he and nodge had similar designs, but both are not ( or no longer ) for sale, and i am not aware they ooensourced their designs
