Discharged to 8v
carbon12
Hi
Through carelessness I allowed a 12v LiFePO4 battery to discharge to 8v a few days ago :rolleyes:. Normally I use it to power some equipment while camping, charging it with a Victron Blue Smart IP22 at 15A or 30A.
I am wondering what I should do now. I see my options as:
1. Treat it as a functional write off, due to internal damage that will stop it working with a useable capacity.
2. Treat it as a safety write off, due to internal damage potentially creating a hazard for sensitive equipment powered by it or to people (gassing, heat, internal short, whatever).
3. Attempt a resuscitation with gentle charging and accept the capacity is likely reduced , but potentially still a useful amount, and use it in the same way as I did in the past (but with more secure protection obviously).
Any advice welcome. Links to authoritative studies/sources about this would also be v welcome.
Cheers
Richard
just apply a charge to it, NOT a heavy high amp one ! if you can 15A is likely just right. It will be SLOW and will require monitoring and it will generate more heat from being at such a low SOC. Once you get to 3.000Vpc (12.0V) let it settle for an hour without charge, recheck and if still above 2.75Vpc / 11.0V (it will settle of course) then you can charge up to full as usual.
It does depend a bit on how long it stayed at 8V. And I ask also, What happened to the BMS?
Just a thought, at 8v, are you 100% shure the BMS is active/on?
There was not a BMS fitted at the time. I have been meaning to fit one for ages, just didn't get round to it before I fluffed it. I used a BattGo to monitor the cells and do top balancing. I just underestimated the power drain this time - like I said, a careless mistake.
Thanks Steve, I'll give it go. Just checked it, the voltage is now 11.37 after standing disconnected for a couple of days so not as bad as I first feared.
