Jah-de-blah-0m
- Jun 25, 2021
- 23
10 12 volt 100 amp hour batteries in series and parallel for 24 volts into lv 24...
Out of the battery bank do both positive and negative need to be fused.
And do both positive and negative need to be wired to disconnect. The manual shows fuse on positive only. I was thinking to connect negative to the battery disconnect and positive to the fuse as pictured here but then thought maybe both positive and negative need to be on the disconnect and both positive and negative need to be on the fuse.
