GXMnow
Solar Wizard
- Jul 17, 2020
- 2,710
I have been looking through the NEC and Los Angeles codes, and I can't find what I am looking for.
My current Enphase solar install has a disconnect switch next to my main panel that will shut down and isolate the rooftop solar gear.
I am adding an Schneider XW battery based inverter. The inverter will power an essential loads panel. The Enphase system will move to the new panel so it is operational in a power outage.
So here is my question
Do I need to have two separate disconnects on the outside of the garage by the breaker panel? One for the solar, and one for the battery inverter?
My original plan is to re-wire the current disconnect to now disconnect the output of the Schneider XW-Pro from feeding the essential loads panel. This will cut any battery backed up loads as well as shut down all of the roof top solar. From a true safety standpoint, I know that cutting off the output of the battery inverter removes the risk of any live wiring past the main breaker panel. But we all know that local codes are not always just what is safe. I am in Los Angeles County, and I have tried searching the local code, but I have not been able to find a section that applies to my setup.
The input side of the Schneider will still be connected to the old 20 amp solar fed breaker in the main panel. But if the power is out, the main is pulled, or the solar breaker is tripped, the Schneider will also disconnect it's anti islanding relay. It will switch to battery power invert mode and drive it's output leads, but that will go to the outdoor disconnect before it feeds anything else. Inside the garage, next to the inverter, I also have an AC disconnect on the inverter input, a main breaker in the essential loads panel, and a battery shut off switch, as well as a manual turn off that will shut down and open the BMS. But my concern is if any of that needs to be accessible from outside by the breaker panel? If I have too, I can punch another hole through the stucco, but I already destroyed one new hole saw to make one hole. I was hoping to not have to alter what is outside of my home, and just adapt the wiring as needed. But I also want to be sure I am legal.
