brandonoh777
- Oct 26, 2020
- 18
I am trying to DIY build my own limiter for a non limiting 1000W grig tir inverter the best idea i have is to limit the DC input much the same was as lower sunlight limits the AC output. So i think this can be done with a circuit consisting of a mosfet (maybe some capacitors to smooth the output) and a Arduino to generate and very the PWM signal to the mosfet. Problem is a mosfet data sheet is intimidating to someone whos neevr seen one!!! ME! lol Can anyone help with the mosfet specs and maybe also cap specs i might want to try...?
inverter-- 24V 1000W so input voltages can range between about low 20's and about 37 (OCV of my panels) its a max 1000W inverter so at those voltages im looking at about 41 amps--prob not much higher than 45 amps and can i drive it with a 5V signal form the Arduino or will i need a separate mosfet driver? thanks!!
Brandon
Brandon
