Melointhesun
- Dec 9, 2021
- 1
I am in the process of buying a land and building a house from scratch and im starting to consider the diffent options for my solar system.
The idea is to have a single phase grid-tied hybrid inverter with a DIY battery bank of at least 16 LiFePO4 cells with 280 ah and connect them in series (SEPLOS BMS)
I would like to request this forum's help with a couple of questions:
1) Assuming the hybrid inverter has CAN connection but does not support SEPLOS BMS, is this a problem ?
2) Is it possible to connect / charge / discharge DYI batteries to any hybrid inverter without using the CAN port ?
3) If so, what would be the disadvantages of not using the CAN port ?
PS. In my country i can request either single phase or three phase meter.
Thank you very much !
