I will install to my house and garage roof solar panels
House Roof: 10X solar panels 440W JA Solar N-type Bifacial Double Glass Traceable LB All Black with MC4
6X solar panels 400W JA Solar (Already installed )
Garage Roof: 6 X 615W AIKO 615W N-Type ABC, 72 Cell, Silver Frame, Gen 2 Cell-level optimisation
1X 440W JA Solar N-type Bifacial Double Glass Traceable LB All Black with MC4
I would like to ask suggestions for Hybrid inverter
theecosupermarket.co.uk
I want to install a DIY battery Li-ion (Seplos) do you know if the FOX inverter will work with DIY battery ?
Thank you
- Rated power: 440W
- VMPP: 32.47 V
- IMPP: 13:55 A
- Isc: 14.31 A
- Voc: 38.9 V
- Temp. Coefficient (Mpp): -0.3 %
- Clamp position on panel: Long and short side
- Connector Type: MC4
- Efficiency: 22.0 %
- Rated Power: 615 W
- Efficiency: 23.3%
- Width: 1,134 mm
- Depth: 30 mm
- Length: 2,323 mm
- VMPP: 49.98 V
- IMPP: 13.68 A
- Isc: 14.44 A
- Voc: 54.29 V
- Temp. Coefficient (Mpp):-0.26 %
- Cable length: 1.4m
- Connector: EVO2
Fox K-Series 10kW Hybrid Inverter KH10 (Single-Phase) (4 MPPT). ?
![theecosupermarket.co.uk](https://theecosupermarket.co.uk/wp-content/uploads/2023/06/Fox-K-Series-Hybrid-Inverter.jpg)
The Fox K-Series 10kW Hybrid Inverter is a groundbreaking solar inverter designed for large scale, single-phase Solar PV arrays and HV batteries.
![theecosupermarket.co.uk](https://theecosupermarket.co.uk/wp-content/uploads/2022/12/cropped-favicon-32x32.png)
Thank you
