Johnmahon
What's Your State of Charge?
- Nov 2, 2019
- 111
Greetings,
With reference to @Will Prowse youtube video that was recently posted (
), I've purchased the same equipment. Due for delivery late July, 2022. Watts247.com's LV6048 and SignatureSolar.com's EG4-LL 48V 100AH rack mounted batteries (x3).
Here is where I am hoping someone can help me out. I have a grid tie home solar (15Kwh) system that produces more than 100Kwh per day (here in sunny Arizona). So, what I am wanting to do is charge these batteries from the grid tied solar system on my home during the day (when I am producing a ton of power) through the LV6048, using the utility priority configurations available within the inverter settings, and then use the batteries to charge my Tesla at night (until the batteries are depleted with each discharge). Granted, with only 3 batteries, I will get 50-60 miles per charge per day, but this is fine for my use case. I only drive about 30 miles per day on average. And I can always add more batteries to the bank as time and budget allow increasing distance.
I also subscribe to a time of use plan with my utility company, where electricity is very expensive during the hot afternoons (2pm-8pm) but from about 8am-6pm, I am producing enough power from my roof mounted system, that I can charge the EG4-LL's during the day, even during high peak hours for free, then use the harvested battery storage at night when I am home for the night. Doubling up on free usage.
Can you program the LV6048 to charge the batteries during a set time period (during sunlight hours) and then discharge the batteries during a set time period (later at night when I am home)? I basically want to charge the batteries during a set time frame, and discharge the batteries during a set time frame. Is this possible? Or, would there be a work around if not specifically programmable using the LCD display functions?
Keep in mind, the batteries and the LV6048 will NOT be tied into my grid tie solar system, as this has already been inspected and approved by the utility company and cannot be tampered with. I will be using the home's grid tie system during the day via the LV6048 to charge the battery bank using the utility as the primary setting. Then, I will use the AC out from the inverter at night to charge the Tesla. There will be no solar arrays connected to the LV6048 whatsoever.
Thanks for any advise you may have!
Sincerely,
John Mahon
Sincerely,
John Mahon
