Yeah that's part of why I used an arduino instead of RPi. Now if you use it only to log data you can disable a lot of stuff (starting with the GPU) you don't need and you can put it to sleep to wake up every minute for example (NB: not sure it works on the latest one, an older RPi might be better for that, and less expensive as a bonus) which should get you at super low power (less than 10 mA).
And 700 mA really depends on what you do, usually it's less than that and you can downclock it to reduce power consumption further.
I can't add serial com to the 16S (and 8S too probably) as all I/Os are used but I was thinking: if you don't use the heater/cooler and aux outputs (J9 and J10 on the BMSB) you can use the built-in serial port (the one shared with the USB chip) but again, simplest and cleanest is just to not use the ethernet shield and use your favorite com instead.
Edit: I've added the power and HWP reset buttons on the last horizontal layout: https://pastebin.com/YRH5Mdkt of course you can still connect external buttons to the HMIB and/or the BMSB if you want
